offtaps avatar image
offtaps asked
Trick to reset automatic battery voltage detection on Bluesolar (no bt, no VE.direct device) ?
Hi everyone,
I remember I've seen a message from Matthijs or Reinout to reset the automatic battery voltage detection on Bluesolar. (Those with firmware > 1.26 Automatic battery voltage detection is only done once at the very first power-up of the charger)
That was something like :
- disconnect everything
- short-circuit the battery output
- powered by solar input
- wait few seconds
- disconnect everything and reconnect correctly (battery first then solar panels)
Does anobody remember such a thing or can confirm the trick ?
MPPT Controllers
nestor avatar image
nestor answered ·
thanks for your question, really helpful.
I had to reset my charger (from 24 to 12V) and i don't have the ve.direct usb connector and don't have the time to get it.
I find this manual on my computer :
manuel-regulateur-bluesolar-mppt-150-45-60-70.pdf
It also explain this method, page 5 , strangely in my manual (paper) coming with the charger this paragraph wasn't there.
So i try it and it work fine. There is a blinking of the leds : once all the led and once the bulk one.
Nestor
