allan-fraser avatar image
allan-fraser asked
SmartSolar 100/30 strange behaviour when overcast
The morning and early afternoon of 4th March were unusual in that, rather than brilliant sunshine, they were overcast with heavy tropical rain showers throughout.
At 14:20, when I went to check how my two SmartSolar 100/30s were doing I was expecting to find them both still in bulk mode but instead I found them both in float mode and, further, the absorption time appeared to be minimal. See screen shots taken at 14:23/24. (I’ve included the screenshots from only one controller as the other one was essentially the same.)
At 07:40 the battery voltages were 12.6v, pretty much the same as always at that time in the morning.
The yield at 14:23 was 310 Wh. By the end of the day this was 580Wh. On a typical day, the yield is in the range 800-1050Wh and the controllers go from bulk to absorption when the yield is 500Wh or thereabouts. (Any other day where the yield is below 800Wh (eg 27 Feb and 1 & 3 March) I can tie back to having the boat’s engine on. And 6-12 Feb, we were in a marina connected to shore power.)
The 100/30s are connected in parallel. Each 100/30 supports 2 * 135 watt panels connected in series. The battery bank is 4 * 125Ah 12v Lifeline AGMs (in parallel). The set up is just over 18 months old.
Can anyone:
  • explain why both controllers went from bulk to absorption when the yield was only 100Wh (vs 500Wh on a typical day) and why the absorption yield / time was so small (it barely registers on the histograms),
  • suggest any tweaks to my 100/30 settings (second screenshot) that might improve things the next time.
Thank you
MPPT Controllers
