i don‘t see my phoenix 12/800 on the Raspberry pi - the USB - VE Bus Cable is plugged in and it works.
the inverter was not found
And the button shows off....
can anywone say what‘s wrong?
Fred-Jürgen
Fred-Jürgen
By ve bus cable are you referring to the one that looks like an ethernet cable?
Or the usb to ve direct cable like the one linked? https://www.victronenergy.com/cables/ve.direct.cable
If it is the latter the only info you will get through the pi is load info. And the inverter will always show as off. It does not have the same data as the ve bus inverters.
I ended up using the ve bluetooth adaptor on mine with victron connect for monitoring since the rest of the system was smart.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
27 People are following this question.
