joao-lima avatar image
joao-lima asked
I need a wiring diagram simple but reliable and economical system.
I need a wiring diagram for the conversion of a van to campervan12v, with daily consumption of 1000w, which includes 2 solar panels of 115w each, a lithium battery 100Ah, connection to the alternator of the van and external connection 220v. I need a simple but reliable and economical system.
wiring diagram
JohnC avatar image
JohnC answered ·
Hi @joao lima
Have a look through the links here: https://www.victronenergy.com/blog/2019/06/18/the-victron-van-install/
This is a display unit that has kit that you may not need, so adjust as you require. There's a pic there of a buck-boost converter on the alternator circuit, which predates the introduction of the Orion Smart, and you could use the Orion instead.
Worth a look through anyway, you may pick up something important to you.
