https://imgur.com/gallery/Sk5Wpkn
I have 2x 12v batteries wired in parallel. However, it seems as if all the midpoint features requires a 24v+ setup.
Does midpoint matter for a parallel setup? Can Victron add in 12v midpoint monitoring?
Hi @Zorrobyte
In a parallel battery setup there is no midpoint.
The batteries voltage in a parallel setup have to be the same.
A midpoint voltage measurement only matters in a serial battery setup (24V, 48V)
Regards,
Markus
5 People are following this question.
