adamflint avatar image
Earthing 24v system
Hi all,
Based on my campervan plans, I am looking at a 24v system, with a few stepped down 12v items using an Orion Unit. I wanted to check if there would be any issues with earthing the system, as it is a 12v van? Anything else that I should be bearing in mind?
Many thanks
campervan
Lyndsay Cotton avatar image
Lyndsay Cotton answered ·
Unless you are connecting to "shore power" (Read mains AC Voltage) and it is a stand alone system - ie 24v / 12 only, I cannot see the need or requirement for an earthing system.
You can also use a common bus meaning that the 24v negative and 12v negative can run on the same wire or grounding.
You will however need to guard against 24v+ and 12v+ coming into contact with each other.
If I am to be corrected, I will modify or alter this post
