Nick A avatar image
Nick A asked
Raspberry Pi 3A+: VRM Portal ID Missing
Just sharing this info, b/c I wasn't able to find a solution online...
I recently installed the Venus OS Large image on a Rpi3A+, after downgrading from a Rpi4 due to power consumption. The VRM Portal ID was always blank, so that portion never worked. Since there isn't an ethernet port, the script in "/sbin/get-unique-id" never gave a proper MAC address. By updating the script to check the WiFi interface, first, I was able to get a valid VRM Portal ID, and everything works as expected.
#!/bin/sh
ETH_ADDR=/sys/class/net/eth0/address
WLAN_ADDR=/sys/class/net/wlan0/address
if [ -f "$WLAN_ADDR" ]; then
    sed -e 's,:,,g' "$WLAN_ADDR"
else
    sed -e 's,:,,g' "$ETH_ADDR"
fi
Hope this helps others!
Raspberry Pi
danner85 avatar image danner85 commented ·
I have the same problem, but i am very inexpert in coding, could someone explain me how to do this mod? How can i update the original script?
scotty306 avatar image scotty306 commented ·
I also have a Rpi3A+,
i have managed to get wifi working (using connmanctl over serial ssh),
but i have the same issue with the VRM ID not using the Wifi MAC address.
Can someone please help with how to update the above script into /sbin/get_unique_id/
Thanks
marc-kelly avatar image
marc-kelly answered ·
Thanks for this.
And for others searching later, connect wifi to the Raspberry Pi 3 A+ using connmanctl. See 1621157917840.png
qubeck avatar image
qubeck answered ·
Maybe it can find its way into the official distro. In a slightly different, more compatible, version of course:
#!/bin/sh
ETH_DEV_SCN=/sys/class/net/eth0
WLAN_DEV_SCN=/sys/class/net/wlan0
if [ -d "$ETH_DEV_SCN" ]; then
SCN_DEV_ADDR="$ETH_DEV_SCN/address"
else
SCN_DEV_ADDR="$WLAN_DEV_SCN/address"
fi
sed -e 's,:,,g' $SCN_DEV_ADDR
This way the sysfs path always defaults to "eth0" if it is actually available.
@mvader (Victron Energy) : If there is an interest in also supporting boards w.o. eth0 as well...
pierresmits avatar image pierresmits commented ·
I would very much appreciate it if this could make it into the 3.0 release. Especially since the limited availabilty of PI 3B+ and P4, this PI 3A (combined with a usb-hub) is a good alternative.
Best regards,
Pierre
2 Likes 2 ·
buddhafragt avatar image
buddhafragt answered ·
with 2.9 it is not working... is there a solution?
felix-schuchmann avatar image
felix-schuchmann answered ·
Just installing a new 3 A+ with Firmware v3.00 and it has a different script. I've just added the board inentifier
raspberrypi,3-model-b-plus
for the 3 A+ and this works for me:
case $(board-compat) in
    raspberrypi,model-zero-w | raspberrypi,model-zero-2-w | raspberrypi,3-model-b-plus)
         if="wlan0"
         if="eth0"
esac
sed -e 's,:,,g' "/sys/class/net/$if/addres
heke avatar image heke commented ·
Works perfect with v 3.13 Thanks.
