stepir avatar image
stepir asked
Multiplus going into charger/inverter loop
Hi
trying to help a customer who has is multiplus (when connected to AC) stuck into a charger/inverter loop (check the attached video)
Your browser does not support HTML5 video.
Can anybody suggest where I should start from to diagnose the issue? Wondering might be the AC tension/frequency causing the disconnect?
THANKS
sandrofelisio avatar image
sandrofelisio answered ·
Thanks a lot for the initial help,
I'm the owner of this, and I can confirm that the AC source is stable in voltage (226V) and in frequency (50Hz).
This happens when batteries are full at 99%.
boekel avatar image
boekel answered ·
I'd first check with a computer + VE.bus-usb cable what is going on. (read AC-in values, etc)
Then seeing if there are settings / assistants that might cause this.
if not helping: update firmware + test again.
stepir avatar image
stepir answered ·
Thanks @Boekel
