Andrey avatar image
Andrey asked
Doesn't set Feed-in limiting active
Hi Victron community!
I try to set ESS with Venus GX, Multiplus II 48/5000 and Fronius Primo 5.0-1.
I made the settings described in the documentation, but Feed-in limiting active shows No.
If switch on "Data export via modbus - tcp" in Fronius that in remote console in Fronius / Device/ Connection solarapi changed to sunspec and appeared string"Zero feed-in power limit 5000W".
So I guess that Venus GX connected with Fronius via Modbus.
And I noticed when in Fronius switch on "Inverter control via Modbus" than in remote console in Fronius/ Status changed from "Running (MPPT)" to "Running (Throttled)".
But in any case, Feed-in limiting active is No.
What could be the matter?
ESS
Hi (sorry can't tag your name)
How much is actual feed-in to the grid? is it limited to 1000W as you set the limit to?
Andrey avatar image Andrey commented ·
Our regulations prohibit feed-in. I made 1000 watts, for example, to see if this setting affects to set Feed-in limiting active in Yes. It doesn't matter what the limit is. I have not connected the multiplus to the grid while the ESS will not work.
Could you please explain to me what conditions must be met for Feed-in limiting active to switch to Yes?
Andrey avatar image Andrey Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
I have checked, the Fronius is set to sunspec: int+SF.
In remote console there is string
Does it make sense to update a firmware of the MultiPlus from 459 to 481?
CristiMV avatar image
CristiMV answered ·
Yes, I am sore
josephm avatar image
josephm answered ·
Hi !
I'm facing same issue when the grid is lost, connect it to the the grid and you will see it turning to ON, I don't know why and almost burn my batteries when the grid went off and I realized it 2 days after :(
