I am using Victron Quattro 48/10000VA. I have controlled GRID feeding (limited) and Battery Charging(limited) without SOC controlled by auxiliary Input (AUX1 or 2 ).
Your question is unclear. If you require assistance I suggest you elaborate.
22 People are following this question.
VRM Battery history [ BMV-712 Smart] widget - "Time since last full charge" with wrong value
What happens when BMV712 sees charging beyond 100% SOC?
BMV 712 partially clear history data
bmv 712 wiring for 48v with mid point
BMV 712 not reseting SOC to 100% even after MPPT 15/75 has reached fully 100% SOC
