goodoz avatar image
goodoz asked
VE Smart Shunt and VE Multiplus dongle...are they supposed to be powered up all the time?
VE Folks -- I have 100A Smart Shunt and a Smart Dongle for a Multiplus installed in my RV (recently). Following VE instructions, both bluetooth devices are connected to the (+) battery post...so they are always powered. My question: For an RV environment where the unit is stored for several weeks at a time (sometimes months) these devices are never disconnected from battery. Are they intended to remain powered up at all times? I realize they have minimal draw (less than 1ma) but it seems odd to leave them powered up. Any advice is appreciated...thanks!
wiring
kaarthik avatar image kaarthik commented ·
Since these are all monitoring units ,its always on powered cant avoid.
goodoz avatar image goodoz kaarthik commented ·
Ok...It shouldn't be a problem since I have 600A of LiFePO4's...Just seems unnatural leaving items powered up for storage...but I understand. I disconnected both of them before I put my rig away...my shunt will need to be recalibrated now...Thanks for your reply.
seb71 avatar image
seb71 answered ·
If stored for months (without charging during this time), disconnect everything from the battery.
What battery do you have (lead-acid, LiFePO4, etc.)?
goodoz avatar image goodoz commented ·
600A of LiFePO4...another forum member says to leave them on. I should be ok. Thanks for your reply.
seb71 avatar image seb71 goodoz commented ·
600Ah means nothing if you leave them almost completely discharged. You must make sure they are charged before storage (but not fully charged).
Do you have a BMS? That also draws power.
Also, is there any risk of below freezing temperatures?
goodoz avatar image goodoz seb71 commented ·
Sure, there's 1 BMS per battery...I don't know if they are pulling power while dormant...rig is stored inside of a warehouse, so no freeze potential...The system is brand new and I've only tested it once...stored the batts at 58% (according to shunt)...https://www.sokbattery.com/products/12v-206ah-lifepo4-lithium-iron-phosphate-battery-pack
