martyduke avatar image
martyduke asked
Bluetooth App Problem
After drawing my battery down to 70% in our RV, I started the generator, and could see, on my Note 20 Android, that our power unit was putting 8 amps into the battery, but the indicator graphic on the app went immediately from 70% to 100% even though the battery had just started getting replenished. The shunt is between the negative post and ground.
VictronConnect
Hi @martyduke,
more info required in order to give help.
  • What's the app you're talking about?
  • Do you have a BMV or Smart Shunt and if yes, what are the settings look like?
  • What type of battery (voltage, chemistry, brand)?
martyduke answered ·
Hi Stefanie, I have two 6 volt wet acid golf cart batteries in series. Here is the other info.
Marty
https://photos.app.goo.gl/4Q1Cd5QmC7uSzufv8
@martyduke,
you can change "charged voltage" in the Smart Shunt setting to something like 14.2V or 0.2V below the absorption voltage the charger/generator is set to. This will prevent the Smart Shunt to synchronise to 100% too early.
