Hi @Robert Dvorak,
What do you mean with "before the smart controller adjusts to battery charge"?
If there is no charge ie. because the batteries are fully charged, then there is no output from the panels and there is no way to see what the panels are able to produce. It always requires a load and it makes no difference whether the load is connected to the panels directly or via the "smart controller", apart from losses inside the controller, which are marginal due to the high efficiency of the Smart MPPT.
26 People are following this question.
