seahaul avatar image
seahaul asked
170 Ah AGM Supercycle as starter
Hello, I have a Victron AGM Supercycle 170 Ah battery that i am moving from my house battery as i got lithium. Can I use it as a starter battery for my Yanmar 4JHE. The specs say it has 600 CCA which is super low for a battery that big.
thanks.
starter battery
jwfrary avatar image
jwfrary answered ·
I mean you can but it probably won’t last long or be very good in comparison to dedicated starter battery that’s designed for the job.
alan avatar image
alan answered ·
it will be fine provided the CCA is within the starter requirements.
A draw is no different between anything, ie inverter, starter, bow thruster, winch etc... its all draw.
The difference between a start vs Supercycle/Deep cycle is CCA, as you have found and discharge cycle life.
A start battery is designed to give off large current, for the size, vs DOD availability, and function working on being drawn to 98% soc. o using 2%.
AGM deep cycle has a lower current availability, but can be cycled many times to 50%.
