By any chance somebody knows if all 6 cables are used at a BMV700?
Or if 4 cables are enough, what I assume (typical in these kinds of connections in electronics)?
Curious! :)
Curious! :)
hi, that would be nice idea to put a link of your item for the ones who like to see/visualize?? ..for sure someone can answer you by memory here!!
Whoever recognizes it is likely one to be able to help....
Cheers
Use pins 1 to 6.
In the case of BMV-700 (without temperature sensor or start battery Voltage sense), pin 2 is unused.
...so I do need at least 5 cables...
I was hoping I can get away with a 4-core cable... ;)
Thanks a lot @wkirby
28 People are following this question.
