Does anyone know if victron are supporting the new Symo/Primo Gen24 models?
Anybody know if they are detected and read by the VenusOS?
So I finally finished my system install, and the Symo Gen24 is detected as a Single phase unknown inverter.
@mvader (Victron Energy) I have to assume that these units will be added? Can we please have monitoring of the PV point output too.
In Fronius GEN24 devices with software version 1.14 or higher, the Solar API interface is not activated by default and must be activated if required (e.g. integration of a GX device).
The setting for this can be found on the user interface of the Fronius inverter under "Communication" - "Solar API".
This used to be a physical toggle switch, and is still described as such in the Victron Fronius integration documentation
I have no idea about the performance of the integration, but that is the advice I have received for how to get it to appear at least.
Please report back with your results and we can improve the documentation.
Does anyone know where the Microgrid (MG) setting is on the GEN 24 Primo Inverter? This is a requirement on the older snap-in inverters, but there is zero mention of this setting or where to find it on the GEN24 inverter? The GEN24 is listed as a Victron compatible inverter, so maybe the MG setting is a default setting.
There's no information about this anywhere, very frustrating!
33 People are following this question.
