falco avatar image
falco asked
MultiPlus UPS function not working sometimes.
MultiPlus 12/800/35-16 with firmware v476, having problems with the MultiPlus UPS function not working sometimes. If I activate the circuit breaker leading into the multiplus, the UPS function kicks in every time. If I get a power failure from the mains, the UPS function works, probably only about 20% of the time.
When the UPS fails to work, If I cut all 12v power with circuit breaker, it seems to reset the MultiPlus and then its starts "ïnverting"
This is a new development, and has worked flawlessly for about 6 months.
Any body have any suggestions.
Multiplus-II
It just turns off completely without an error (red LED) and you have to disconnect the DC power to reset the device?
Paul B avatar image
Paul B answered ·
update to Fw478 there was some abnormal reboot issue with 476
falco avatar image
falco answered ·
To answer Mathias question its a green light on the inverter when this happens.
Battery is a 200 ah lifePo4
Photo 3 is when the inverter is working correctly.
Cant find a firmware any where on the internet, so cant upgrade.
You need to make an account here.
But latest VictronConnect should also have FW478.
For firmware update of a Multiplus, the MK3-USB interface is required.
falco avatar image falco seb71 commented ·
Thanks for your reply Seb. I am awaiting a OTG adaptor for my phone so I can try the firmware update on Victron Connect. Is this going to solve my problem though. This Victron setup has worked ok for six months, on the v476 firmware. Anyhow I have the Mk3 to USB interface so will try the firmware upgrade. I'm starting to think this may be the battery though. Its only a month old.
