curtis-parker avatar image
curtis-parker asked
Quatro 12/500/120 charge rate.
I'm looking at Quatro 12/5000/120. to "charge" the batteries only. im looking at this device because of its high amp charge rate. I'm assuming the 200 amp charge rate is if I am inputting 120 volt 50 amp. My problem is the input to this device will only be 120 volt 30 amps. At 120/30 input what would my charge rate be? would it be cut down to 120 amps?
120Vac * 30A = 3600W
3600W / 12Vdc = 300A
So you can use the full charging power of the Quattro at you 120V/30A grid.
