paul-p avatar image
paul-p asked
Over powering smart solar controller
Ive got a smartsolar 100/20 yet to be installed. This is going into my caravan and am loking to get 2 house panels to mount flat on roof. Using the victron excel spreadsheet when i input 2 x190w panels in series or parallel it comes up warning of over 30% overpowered. Originally was looking for 2 x170w panels in series but 190s seem easier to get. Would using 180s be a problem?
MPPT Controllers
seb71 avatar image
seb71 answered ·
Look at VOC for the panel.
String VOC must be under 100V for that charger. Leave some safety margin for cold temperatures, when the voltage can be higher.
Also, usually 60 cell panels have best prices per Watt.
haudidier avatar image
haudidier answered ·
your smartsolar 100/20 is limited in solar voltage. Its maximum input voltage is 100V DC.
So if you put two panels in series, you have to check that 2xVoc < 100V (Voc is the open circuit voltage of your panel, see the datasheet of your panel).
And as seb71 says, "Leave some safety margin for cold temperatures" because when the temperature decreases, the solar voltage increases.
4 comments
paul-p avatar image paul-p commented ·
These panela are 44.5v voc. Coldest temp here would be 4 degrees Celsius
haudidier avatar image haudidier paul-p commented ·
To calculate the temperature-corrected Voc, the panel temperature coefficient V temp must be known [%/°C]
But for 4°C the Voc don't increase a lot, so if you have only two panels in serie is is OK for this smartsolar.
As for the power of your smartsolar, it can produce a maximum current of 20A.
Now if it is connected to a 12V battery system it gives a max. power of 12*20=240W max.
For a 24V system => 24*20=480W max.
As you want to use two 180W panels, they should be able to produce 360W.But this is impossible because you are visibly using 12V system, and in this case the maximum power converted by this smartsolar is only 240W.
haudidier avatar image haudidier haudidier commented ·
Because Your 2xVoc is < 100V, this will not damage the smartsolar, it will simply limit the converted power to 240W (at the maximum of the day), but the advantage is that it will start producing earlier in the day and stop later.
paul-p avatar image paul-p haudidier commented ·
Thanks for the info. Researched this and having 2 in series is exactly what you said. Starts earlier and finished later. Yes its a 12v system with a single 120ah agm. More worried about the more than 30% oversizing on the controller.
