Tom avatar image
Tom asked
Multiplus Not Switching to Shore Power
I have a Multiplus 3000/120 with 30 AMP shorepower connection. The UPS setting is disabled.
My Multiplus was automatically switching to shorepower when connected but I discovered this morning that its not switching over to shorepower to charge my Victron 200aHr batteries. I have not changed any settings in several months.
I checked my wiring and I'm receiving 120 volts to the terminals inside the Multiplus & batteries chare via alternator and solar panels.
Where do I look next?
Tom avatar image
Tom answered ·
Apologies... just realized that I had not closed this one. The Multiplus was replaced via warranty replacement.
seb71 avatar image
seb71 answered ·
Do you have a MK3-USB interface? It could help to see why grid is rejected.
Tom avatar image Tom commented ·
I uploaded a screenshot. Where should I be looking for specifics on why the AC1 is disconnected? thanks again for the assistance.
Tom avatar image
Tom answered ·
Yes, I do...tell me what to look for. I dont remember see any alerts when I look at the Multiplus earlier.
VE Configure 3 will highlight the issues it finds (such as frequency too low or too high, Over/under voltage).
Tom avatar image
Tom answered ·
Attached is a screen shot from Victron Connect...not sure why the AC input is disconnected. I checked my Cerbo and there was overcharge notification two weeks ago.
I'm using the recommended settings from an authorized installer; I called them the other day and we verified the settings.
Also, nothing happens when I manually switch it to charge or do the same via the GX panel/Cerbo.
I said to check with VE Configure 3, not with VictronConnect.
Tom avatar image
Tom answered ·
ve3screenshot.pngApologies...I'm attaching a screen shot. No assistants are loaded. Let me know if you need additional info.
alan avatar image alan commented ·
This show no voltage on the AC1 input. If there is voltage on the input terminals verified by a multimeter I'd say its faulty.
Tom avatar image Tom alan commented ·
Thank you Alan...I have opened a service request with the provider and they have opened a service request with Victron to get it replaced/repaired.
Tom
Tom avatar image
Tom answered ·
Thanks for the responses...I forgot to update this question. Multiplus was replaced by repair service.
strockerace avatar image strockerace commented ·
Tom, did you ever figure out what the problem is. I have the same issue with mine.
I have it plugged into shore power but nothing registers.
