rohan-chinni-c-l avatar image
rohan-chinni-c-l asked
Victron connect android app add classic Bluetooth scan feature
Hi everyone!,
This is my first post and my first question, I recently bought Victron Bluesolar MPPT 75/15, and I made a custom usb cable using Usb to UART module and I could connect my controller to the victron connect software on windows and the victron connect app on Android, but I wanted to connect wirelessly with Bluetooth, so I have used HC - 05 Bluetooth module and connected it directly to the victron bluesolar Mppt to the communication port.
By doing this, I was able to access and change the configuration of the Mppt controller via Bluetooth from victron connect software in windows, but I also want to access my controller via Android app instead of turning on the computer every time.
So I request to please add the classic Bluetooth scan functionality in the victron connect android app, as currently the android app only searches for Bluetooth low energy devices. But the HC-05 Bluetooth module is not Bluetooth low energy, and it's Bluetooth version is 2.0.
Thanks.
Bluetooth
javierpilote avatar image javierpilote commented ·
Hi
Do you mean that you have connected a ve.direct cable to the MPPT ve.direct port and at its end a bluetooth HC-05? And then from Victronconnect in Windows 10 have you connected to the Bluetooth HC-05 (through the windows bluetooth)?
rohan-chinni-c-l answered ·
Could anyone please help me with this, or is there any other way of connecting from android app?? via Bluetooth version 2.0??
Thanks
ion avatar image
ion answered ·
@ROHAN CHINNI C L, what setting did you use for HC - 05 Bluetooth module in order to make it work? I am trying to this on a MAC, but it doesn't work. I can connect through a simple usb to TTL adapter. For HC-05 I used the recommended settings:
Baud rate: 19200
Parity: None
Stop bits: 1
rohan-chinni-c-l avatar image rohan-chinni-c-l commented ·
Hi @ion, I used the same settings as you have described. The OS which I was using was windows 10.
