wmuller avatar image
wmuller asked
Battery monitor showing charged voltage but showing low amps
Hi guys
Wondering if theres a strange setting I need to adjust as my battery monitor is showing my 170ah deep cycle battery is at about 12.9 volts fully charged. Am using a Projecta 25a DCDC charger also. But when it is at this voltage (which should be around %100) it says its at about 55% charge when cycling through the battery monitor and that it is showing it has drawn 60amps even though nothing is draining the battery at the moment. Had a play around with using the %100 setting but that only worked temporarily. I Have the Victron 712 Smart battery monitor.
Thanks in Advance
BMV Battery Monitor
Paul B avatar image
Paul B answered ·
First of all some basic LA firgures, these are presuming a GOOD battery with no cell sulfation or shorted cells
A lead acid AGM GEL Flooded etc are normally 100% full when at rest for min 1 hr and a voltage reading of12.7 to 12.9 volts.
That being said
when a LA battery is being charged it needs to see 14.4 volts for 8 hrs and the charger should drop to float voltage which is around 13.4 to maintain level
The above is a indicative set of numbers meant as a ruff example and depend on the battery manufactures figures of course.
Now on on a solar system (you have not mention that so this may not apply ) the mppts will charge to the absorption for its set period 4 or 8hrs there abouts depending on settings to fill the battery to 100%
then float then over night to the batteries standard voltages the below chart is for a battery at Idle and thus must have no charge or discharge for 1 or more hrs, some batteries maybe .2 volts higher so adjust chart to suit
NOW TO THE BMV Question
set the BMS to show charged at say 14 volts and set the period to say 4 hrs at this point the SOC will flip to 100% (if this is not achieved then there is no reset done)
Its always a good idea to have a reset done as LA batteries are not perfect and every battery is different as well and thus the in and outs of the amps flow is not measured correcty unless Peukerts exponent is 100% correct and you may also have to adjust this to suit your battery.
Thus a reset to a known 100% level is a good starting point
also set the Battery capacity to the correct figure
it will then only reduce if there is a current draw. and a reset to 100% happens when it is at a 100% level
