I understand the Orion-tr would work for the job, but is the Orion-tr smart going to do the same thing but better?
thanks!
thanks!
Hi @Lilyluck, welcome to the Community!
The Orion-Tr is not a charger, it's just a converter, so -since it doesn't put out an intelligent multi-stage charge profile- it is not generally recommended for use for charging a battery. The Orion-Tr Smart is the correct product for this.
Generally speaking, your 24v start battery will be charged directly from your 24v alternator; then, to charge your 12v house bank, you'll use the Orion-Tr Smart 24/12-30 connected to your start battery on the input side and your house bank on the output side.
22 People are following this question.
