Dosheimer avatar image
Dosheimer asked
Multiplus 12/3000/120-50 230: How long severe voltage after switch-off?
Hi!
I would like to know how long there could be a touch/contact voltage dangerous for persons after disconnecting the inverter from the 12V battery and 230V power supply.
Or asked the other way around: After which time it would be safe?
Many thanks in advance for your response!
The AC output should be safe to touch almost immediately.
At the battery terminals the capacitors need a few minutes to discharge.
