fenix avatar image
fenix asked
Dc to dc Orion-Tr Smart DC-DC charger isolated
Hello
i have install today the new Dc-Dc isolated 30 amp
here's my setup
Truck battery - guage2 wire 25' - breaker 80amp - , gauge 8 wire 2 ' - battelborn 2x100
i purchase this unit to increase the voltage and have 30 amp to recharge the Battleborn
Lipo battery need more than 13.6 to charge
so far i was not able to get good voltage on the camper batteries
- the Bluetooth signal is not good. Compare to my other unit (all at the same place)
- what setting should be done to get higher voltage?
example
truck alternator is at 14.5
output is a 13.3
link to Lipo battery
How to Find Happiness With LiFePO4 (Lithium-Ion) Batteries - Solacity Inc.
Orion DC-DC Converters not smart
lee avatar image
lee answered ·
The Lipo battery will have specs including charge voltage, max absorb time, bulk voltage, etc. I do not know the Orion but it should be able to be adjusted to those numbers. You may need to select LiPo as the battery type or may have to select advanced and set them yourself. The LiPo mfg may be able to help you as they will know the battery requirements.
fenix avatar image
fenix answered ·
I am very disappointed by the Orion
It start at 30amp then reduce rapidly to 20amp
During winter..my system need full batteries fast
