jaketsu avatar image
jaketsu asked
Is it OK to install Quattro 48/5000 in to road vehicle?
I´m planning a maintenance vehicle and I need three-phase current in it mostly for a welding machine. So I was thinking of 3 x Quattro 48/5000, but then I noticed this Quattros datasheet line: "Road vehicles 12V and 24V models: ECE R10-4". Does it mean that only 12V and 24V Quattros are allowed in road vehicles?
Thank you.
Johannes Boonstra (Victron Energy Staff) avatar image
Johannes Boonstra (Victron Energy Staff) answered ·
As far as certification, the E approval is for Europe and not outside this area.
As far as the units , they are perfectly fine (when installed correct ) when used in vehicles
As far as voltage , there are step up options or you can choose to keep the three phase isolated from the vehicle electronics
jaketsu avatar image jaketsu commented ·
Thank you very much for your answer Johannes.
Lyndsay Cotton avatar image
Lyndsay Cotton answered ·
I will be guessing / shooting from the hip but would it not be that the inverter would need some form of base (starting voltage) and typically a road vehicle would only be 12 or 24 V for this.
I will also be keen to get the correct answer
