Does anyone know if the Multiplus 2 is UVRT compliant for use in South Australia under their new inverter requirements?
I don't think this feature is available now but I guess it should be possible to add this feature with a firmware and VE.config update.
22 People are following this question.
Multiplus 2, load the Battery function not needed
Suitable Circuit breaker between multiplus-ii and battery
Leaving MultiPlus voltage sense connected when battery disconnect switch is OFF.
Multiplus II connected to AC Mains
Multiplus-II loud humming without load, Error 8/11 when set to charger/inverter mode - dead ?
