I currently have a fairly new PSW Magnum Inverter that provides all the power needed. So I am not prepared to get a new inverter in the foreseeable future. I am looking for a way to populate the AC Input and AC Load fields in the gui from my VGX
This data is read directly from the Victron inverters using their own interfaces and communications protocols. Other manufacturers would not use the same interfaces or protocols, so this information cannot be read out.
What is this wireless AC sensor field for in the Cerbo?
That AC sensor is intended to measure the power from a grid tied solar inverter and it actually needs to be connected to an existing MultiPlus or Quattro.
24 People are following this question.
