kyleolmstead avatar image
kyleolmstead asked
Battery Isolator & Alternator Sense Terminal
I have installed an Argo Fet Battery Isolator. It works well, but when the batteries are full, I am getting a reading of around 15.1 volts at the battery, which I understand to be too high. When I installed the battery isolator, I removed the wire from the sense terminal of the alternator. Should I reconnect that? and if so, to where?
alternatorArgo FET Diode
