Hello there.
I have a BMV-700. I dont know what I should change the settings to as I am charging with 3 devices. Alternator, solar and shore.
Please help,
DENNIS
Hello there.
Please help,
DENNIS
Hi @EpicAdvanture,
it is impossible for the BMV to differentiate the charging sources, so it should be OK as it is?
Regards,
Markus
Well i didnt chage the settings when i installed it. There is a video saying I have to change the settings when using solar? What is the settings for that? I dont understand what to set it to. Thanks you for the quick response by the way.
Maybe this blog post is worth reading. It covers everything important:
instructional-video-how-to-optimise-the-bmv-700-series-sync-parameters
Regards,
Markus
Do you have a link to the video that you saw? Maybe there is something in there that you saw which is or isn't in the same context that would apply to you.
What Markus said is right, there aren't any settings to differentiate energy sources for the BMV.
The victron installation video said that when using solar, I need to adjust the settings accordingly.
Yes, that's exactly the settings I dont know how to set. Can you help me figure that out? I have 3-100 amp hour sealed lead acid batteries wired in parallel . 12 v, 300 ah. @Boekel
because your system can charge slow due to low sun input: have the charged voltage high, like close to the max (absorbtion) voltage, the charged current is tricky, I'd start with 1%
if you really want to get it right, you can choose to not let the BMV sync itself by setting the voltage even higher, this way you can check if the SOC drifts up or down from what it should be (should be 100% when absorbtion is reached and the battery doesn't accept more than x current)
Change charge efficiëncy and peukert factor to finetune.
Thank you. That makes much more sense than the instruction manual. Now what about when charging from my alternator? I have an 180 amp alternator. Will those same settings work?
yes the alternator will have a set voltage it charges up to, when the battery is the same voltage it will not draw current anymore.
Just realise it's impossible to always have exact state of charge on lead acid batteries, if you always stay on the safe side when discharging (no more than 50% discharge on regular lead acid batteries) than this should not be a problem.
Victron BMV battery monitors product page
6 People are following this question.
