lawrence-craig avatar image
lawrence-craig asked
Sizing an Inverter/Charger with Generator and 12v system
Hi there.
I have a 3500W continuous output generator (230v) on my boat. I also have 3 x Bosch C20 140aH (420aH) 12V batteries. I would like to buy a battery charger and would like to maximise the battery charging to minimise the generator run time. What best size Mulitplus should I go for and why?
Thanks!
N.B. I currently have a Centaur 12/40amp charging the batteries from generator but looking to upgrade to an inverter/charger.
jwfrary avatar image
jwfrary answered ·
2C would be 84 amps so that would be your safe charging target so a 2000 compact multi plus would be about right.
If you really want to charge fast switch to lithium.
A gx device and genny auto start really transforms the system.
kyle-mccombs avatar image kyle-mccombs commented ·
What does the GX do to benefit the system? Auto Start can go right from the multiplus I believe?
Kevin Windrem avatar image Kevin Windrem kyle-mccombs commented ·
The Multi is able to control the generator based on load, battery voltage and state of charge. A GX device adds
  • Quiet time to prevent running generator at night (with low SOC override)
  • Manual run
  • Automated maintenance run
  • Easier to control if changes are needed on a regular basis
