Hi! is it possible to Switch the Relais on a High SOC? between 95 and 100% ? i cant do that by voltage, because i run Lifepo Batterys.
Simple answer is Yes. It is an setting you can do via Victron Connect.
yes but unly up to 99%, over 99% the relay switches off again, also in ruins your "time untill empty"
23 People are following this question.
