Bonjour,
Pouvez vous m'indiquer s'il y a un moyen pour communiquer avec le Multiplus 3000-120-50 par l’intermédiaire du Bluetooth et VE Connect.
Merci pour votre réponse.
Bonjour,
Bien compris.
Peut-on remplacer le processeur avec un plus récent ?
Merci.
That's a "no" again, sorry.
I'm not sure if a whole new mainborad (not sold seperatly to end users) would work with old hardware, but I guess not.
If you really need this feature you have to buy a "new" Multi.
The number on Sicker on the CPU have to start with 26.
Bonjour
je confirme, c'est une ancienne génération de processeur.
il n'y a pas de mise a jour disponible qui puisse permettre de faire fonctionner un vebus smart dongle désolé.
Unfortunately not, you device is to old for that.
The VE.Bus Smart dongle needs at least a firmware version of 415 but the latest version for your device is 159 and 209.
https://www.victronenergy.com/live/vebus_smart_dongle_manual
You can use a GX device to get access to some informations of your Multi via LAN/WLAN or trough the VRM Portal.
Merci pour cette information,
Peut on mettre à jour la version la version de l'appareil afin de pouvoir utiliser une connexion Bluetooth ?
(Thank you for this information, Can we update the version the version of the device in order to be able to use a Bluetooth connection?)
Do you see that big chip in the upper left?
That is the CPU and the number on that sticker identifies you device.
The first 4 numbers are the hardware ID and the last 3 are the stock firmware.
The 19 identifies your device as an old one with the old small CPU and for that CPU is no firmware available that makes you Multi compatible to the Bluetooth dongle.
22 People are following this question.
