Aleksandar Malenic avatar image
Aleksandar Malenic asked
MPPT 250/100-MC4 VE.Can all possible ways to connect the PV array to all 3 pairs of the MC4s
Dear all,
let me ask you about the possible electrical benefit of 3 pairs of MC4s.
In the production manual nor on any official video is given this explanation.
Does it mean:
-each PLUS MC4 and each MINUS MC4 is internally connected on the board short so it only can accept 3 identical PV arrays with same voltage, same current, same place orientation to the sun so only PLUS is using it as a parallel point to eliminate thick cabling?
- it enables connection of max 3 independent PV arrays with different voltage and roof orientation and has advantage like multi MPPTs so one chain is 220 V orientated to the east and second chain to south with 150 V and third chain with 180 V to the West?
I really hope it is the second option as I would really welcome it. :-)
If not I have to use several MPPT 250/100-MC4 VE.Can for each array. :-(
Thank you for your answers and experience sharing.
Alex
MPPT Controllers
Paul B avatar image
Paul B answered ·
your first option is correct
-each PLUS MC4 and each MINUS MC4 is internally connected on the board short. all the 3 positives are joined inside and all 3 negatives are joined inside. the extras are there so that you can spread the load over 3 of them if required.
Aleksandar Malenic avatar image Aleksandar Malenic commented ·
Thank you Paul for your fast reply, I appreciate it. I will try to still connect different chains with different orientation and voltage parallel but via Shotky high voltage diode and I expect no more power disipation than 5 W max as the max current per chain for panels I use is 10A and the direct voltage drain 0.5 V when the diode is open.... This should work so one device can be used....
Cheers and let me wish you a great day.
Alex
michelg avatar image michelg Aleksandar Malenic commented ·
Hi Aleksandar, usually the PV panels have their own shotky diodes installed in the black box in their back, where the +/- cables are connected.
Michel
