xsilvergs avatar image
xsilvergs asked
RPi Venus with Node-Red proxy access problem
New here but I'm used to Node-Red.
Firmware version v2.60~38-large-image-6
Build date/time 20200819194100
Node-Red is running on my RPi 3 B+.
In Settings > Services Node-Red is enabled.
I have a flow with an inject button which is changing the state (1 or 0) of a Relay Control node and I can see the GPIO pin for relay 1 change state. I have also added the node-red-dashboard node and included a button.
From what I understand I should be able to view this remotely.
From https://vrm.victronenergy.com/installation/nnnnn/proxy/
When I click the big Node-Red button under "Proxy Relay" a new tab is opened and I get this message in the browser at https://nnnnn-nodered.proxyrelay1.victronenergy.com
Error: remote installation does not seem to have a running Node Red service.
Hopefully someone may be able to give me a clue as to why I can't view the Node-Red page?
Thanks
Node-RED
Mark avatar image
Mark answered ·
A few minor firmware updates were necessary to get remote NodeRED access working. If you just upgrade/install the latest non-beta v2.60 extended FW those changes are included and it should work per the online manual.
xsilvergs avatar image xsilvergs commented ·
Is Firmware version v2.60~38-large-image-6 not the latest? If not do you have a link to a working image pleas?
Mark avatar image Mark ♦♦ xsilvergs commented ·
No its not the latest. A non-beta version of v2.60 extended FW was released in September and is currently the latest.
You can download the appropriate FW from here: https://www.dropbox.com/sh/i8ru22o4ydws1rx/AADpa8lj5s2APZ2JS78OGPjKa?dl=0
xsilvergs avatar image xsilvergs Mark ♦♦ commented ·
Thank you. I'm not sure how you tell easily which are beta but v2.60-large-image-7 works.
many thanks
