jozef avatar image
jozef asked
BS MPPT 100/15 charging problem
Hi there
we are using 2pcs BS MPPT 100/15. Since 2W ago the production goes really down. Its placed on Bahamas and the weather is really good here. Can you help? I control the Voltage, current, cells is quit fine (Uoc=90V, Ics=9,5A)
(that day 13. dec., system was connected to grid and charging from grid)
MPPT Controllers
@jozef
Heat causes derating. Panels may be hot or the mppt?
You say you were connected to the grid you also have more to your system then, are you able to share more details about your setup?
jozef avatar image jozef Alexandra ♦ commented ·
Hi
weather there is like 28°C so this issue, I don´t thing soo
Yes I can share you more info, but via email please
what kind of details you need?
Alexandra avatar image Alexandra ♦ jozef commented ·
If you disconnect from the grid do the mppts wake up and do any work?
There may be a setting that needs to change.
My panels get up 50°sometimes higher in ambient temps of 25° so panel temp has nothing to do with ambient temps. Mppts can get over 55° when they are working hard as well.
We have our one 75/15 on a aluminum heat sink because it get very hot when it is working in midday.
jozef avatar image
jozef answered ·
Perhaps you could share your solar yield/energy consumption plot, eg....
klim8skeptic avatar image klim8skeptic ♦ klim8skeptic ♦ commented ·
Addition to last post...
jozef avatar image jozef commented ·
Hi there here is the solar yield/energy cons.
Paul B avatar image
Paul B answered ·
sugest you get a victron bluetooth dongle and connect it to the BS units VE direct port and then using victron connect app, have a look at the history of the unit as it will show you the High and the low voltage of every day for the last 30 days. this may then give you a better idea.
This values I can see on pictures higher (in this chat) and also via Remote Console (it´s much easier than travel 2000 km). And as I write Uoc is correct and Isc too.
