galaico-mobility avatar image
galaico-mobility asked
multiplus 12/800/35 programation
Hello, I would like to know if there is any way to program this equipment, so that when the switch is in position 0, that is, it is completely off, and 220v is applied to the input, allow the passage of this voltage to the output, I have the interface to be able to program it, thanks
You can unplug the input/output GST-18 plugs from the inverter, then plug the input lead to the output lead.
Alexandra avatar image
Alexandra answered ·
@Galaico Mobility
https://youtu.be/96tI8sqOPEU
The feature you are requesting is available when you are in charge only mode. It will allow passthrough when in this position.
Off means really off. No charging no inverting.
"Off means really off. No charging no inverting." - No pass-trough
