rien avatar image
rien asked
multi 12 1600 70 bulk charging lithium
on my boat the multi is charging a life po4 200 amps battery bank.the charge comes from a 1000 watt constant rpm generator. I like to cycle the battery bank between 80% and 25% state of charge. there seems to be no way to set the multi so it does bulk charge with constant current until the battery bank reaches 80% state of charge and than stops charging.the voltage rises until it reaches the set absorbtion voltage and than tapers off . I can set the maximum charge current in the victron connect software but I can.t interfere with the bulk time. since the generator is not a modern inverter type that lowers the rpm when there is less demand it means that there is a lot of fuel wasted is there any way I can set up the multi so it charges more like an engine alternator does.
Perhaps you could edit your post into logical paragraphs..
Plz..
It would also be helpful to know what your settings are
