Why on the multiplus 3000/120 does victron recommend 2- 1/0 dc power lines instead of 1- 4/0 from battery?
4/0 or 120 sq mm cables are extremely hard to work with. Relative to two half the size.
I have longer than desired cable runs in a tight class B rv. In order to route the cables I used dual runs of 2/0 ultraflex welding cable which gives lower voltage drop that a single 4/0 cable. I found these online at a discount because it was left over from end of rolls. It works well and very easy to route.
25 People are following this question.
