rikesh avatar image
rikesh asked
Which MPPT for 8x400w Sunpower Maxeon3 solar panels
I have
8x400w Sunpower maxeon3 panels which have a VOC of 75.6 so would like your suggestion on the Victron MPPT to use.
VOC-75.6
I tried the calculator but having difficulty ..
Thinking - a DC-coupled - 2 panels in parallel on each of the 4 x 100/20 48V Smart solar charger controller.
Any suggestions??
MPPT ControllersMPPT SmartSolar
4 comments
What is your system voltage?
rikesh avatar image rikesh Matthias Lange - DE ♦ commented ·
48 v system
klim8skeptic avatar image klim8skeptic ♦ rikesh commented ·
Series stacking of your panels gets expensive quickly ...
Parallels pairs on a cheaper mppt's comes up cheaper when array series fusing is not required.
Extra mppt's to monitor is a headache though...
Vance Mitchell avatar image Vance Mitchell commented ·
'4 x 100/20 48V Smart solar charger controller' should work ok on a 48v system.
Another option if you haven't purchased your controllers yet would be one of the new RS controller . That would allow for alternative wiring options such as 2 strings of 4 in series to reduce cable losses.
