Good day to you all,
I have installed the following:
Solar array : 800W (Voc 43V)
1x MPPT charger is 100/50
1x Battery: Super pack 25.6V
The system worked well until, the battery was fully discharged and low voltage protection activated.
Than the MPPT couldn't start recharging the battery again. Voltage at the battery was 14.7 V with solar panel input (in float mode), and 0V without.
I discovered later that MPPT voltage auto detect was the issue, and changed the settings manually to 24V using the app. It looks like its working. I am waiting for another blackout to see it MPPT remember that setting.
My question:
Could the prolonged application of 14V (see in red below) from the MPPT on the battery had done some damages to it? Knowing the battery is not supposed to go below 20V.
Thank you for your inputs
Cheers
Nico
Days ago | Date | Yield(Wh) | Max. PV power(W) | Max. PV voltage(V) | Min. battery voltage(V) | Max. battery voltage(V) | Time in bulk(m) | Time in absorption(m) | Time in float(m) | Last error | 2nd last error | 3rd last error | 4th last error |
0 | 12/9/2020 | 0 | 220 | 42.07 | 0 | 23.8 | 3 | 5 | 225 | 34 | 0 | 0 | 0 |
1 | 12/8/2020 | 0 | 1 | 42.89 | 0 | 14.78 | 0 | 3 | 518 | 34 | 0 | 0 | 0 |
2 | 12/7/2020 | 0 | 2 | 43.65 | 0 | 15.1 | 0 | 3 | 260 | 34 | 0 | 0 | 0 |
3 | 12/6/2020 | 0 | 2 | 43.65 | 0 | 14.91 | 3 | 1 | 341 | 0 | 0 | 0 | 0 |
4 | 12/5/2020 | 20 | 3 | 43.91 | 0 | 14.78 | 0 | 2 | 802 | 0 | 0 | 0 | 0 |
5 | 12/4/2020 | 1120 | 615 | 43.65 | 0 | 28.66 | 419 | 90 | 290 | 34 | 0 | 0 | 0 |
6 | 12/3/2020 | 1870 | 811 | 42.86 | 25.38 | 28.7 | 416 | 64 | 314 | 34 | 0 | 0 | 0 |
7 | 12/2/2020 | 490 | 568 | 43.65 | 0 | 26.25 | 228 | 4 | 198 | 34 | 2 | 34 | 0 |
8 | 12/1/2020 | 0 | 2 | 43.09 | 0 | 14.84 | 1 | 3 | 494 | 34 | 0 | 0 | 0 |
9 | 11/30/2020 | 0 | 1 | 44.44 | 0 | 17.14 | 1 | 1 | 616 | 0 | 0 | 0 | 0 |
10 | 11/29/2020 | 2100 | 803 | 40.75 | 0 | 27.35 | 808 | 0 | 0 | 0 | 0 | 0 | 0 |
11 | 11/28/2020 | 2480 | 845 | 41.68 | 24.23 | 28.52 | 781 | 7 | 17 | 0 | 0 | 0 | 0 |
12 | 11/27/2020 | 2000 | 800 | 43.55 | 24.5 | 28.67 | 540 | 9 | 265 | 0 | 0 | 0 | 0 |
13 | 11/26/2020 | 2820 | 693 | 41.42 | 24.45 | 28.5 | 760 | 50 | 0 | 0 | 0 | 0 | 0 |
14 | 11/25/2020 | 2360 | 770 | 43.55 | 24.48 | 28.74 | 494 | 90 | 220 | 0 | 0 | 0 | 0 |
15 | 11/24/2020 | 2460 | 843 | 42.42 | 24.58 | 28.5 | 535 | 18 | 251 | 0 | 0 | 0 | 0 |
16 | 11/23/2020 | 2270 | 881 | 43.26 | 24.52 | 28.63 | 588 | 80 | 132 | 0 | 0 | 0 | 0 |
