khargreaves avatar image
khargreaves asked
Isolation Transformer Mounting
Can the 7000 Watt Isolation transformer bo mounted sideways? Meaning the back is mounted on a vertical wall with the glands of the cables facing right and the top of the unit facing left. Or can it be mounted on a horizontal surface lying on its back? Thanks, Ken Hargreaves
Multiplus-II
Paul B avatar image
Paul B answered ·
The best way to to mount is vertical as this allows for convection air flow.
You can the unit any way but then a high load usage you may need to add a cooling fan
