davidk-1 avatar image
davidk-1 asked
Pylontech UP2500 with Easysolar 24/3000
does anyone know if i can run the Easysolar 24/3000 with two Pylontech UP2500 (parallel connection)?
Unfortunately i can't find any information on this page: https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
Data of the UP2500 (24V):
Charge/Discharge Current(A ): 56(continuous) , 111 (Peak@15s)
Cheers
Alexandra avatar image
Alexandra answered ·
@David.k
With two batteries you should be fine.
3000kva is 2400W continuous power
2400w ÷ 24v = 100A draw from the battery plus losses. The 56Ax2 units is more than enough to keep up with the full load discharge.
And the peak will keep up with the occasional overload if you do.
