Trying to setup an ET112 meter with a Zigbee RS485 and Zigbee USB pair. I have followed the instructions at this link https://www.victronenergy.com/live/energy-meters:et112 but I am not having any success in establishing a connection. The system is using a MultiPlus II GX for connection of the Zigbee USB converter.
As it is not working out of the box, as I thought it would, I'm trying to figure out what the LED lights are telling me is wrong but I can't find any information on this. I also can't find any information on how to use the pushbuttons to try and manually establish a connection or reset.
I'm getting a constant blue LED on the Zigbee USB but no blinking of the TX/RX led as the instructions suggest.
The distance is about 15m from one side of the building to the other. There are some internal walls but with a range of 1600m I'm hoping that this is not causing an issue.
So the questions are; how do I use the pushbuttons and how should the LED's be when a connection is established?
Thank you for any assistance.
