mae avatar image
mae asked
Quatto indicator low battery
Hello I need help not the manuals! I'm desperate! It turns out that this morning we miscalculated and we have used up all the batteries. We have run out of energy. We are off the grid. We have no alternative to energy.
The batteries began to charge but the electricity did not return home. I have been touching in the app where the programming is and I think that the error code is not eliminated in the Quatro device and the indicator of low batteries continues flashing but there is 64% of the charge but The electricity is not coming home and I am on the verge of an attack. The food is going soon to the trash and we don't have water either because it goes through the electric pump.
Does anyone know what I can I do in the programming so the quatro returns to its programming and does not continue giving low battery error?
Has anyone had this problem?
Current battery voltage? Low-voltage reset setting? What components do you have?
Only one Pylontech module for a 8kVA Quattro? For such a system you should use at least 6 modules.
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
mae avatar image mae Matthias Lange - DE ♦ commented ·
Hello Mattihas I have
have 4 batteries 48v.Venus; a charge controller and the Quatro.
mae avatar image
mae answered ·
Hello Matias! I have 4 batteries 48v. ; a Venus; a charge controller and the Quatro.
