vivabavaria avatar image
vivabavaria asked
Victron Multiplus 12/1200 does not charge
Dear Community,
i have a fairly new Victron multi 12/1200 (charged 3 times with it already) and I run a LiFePo4 200 Ah with BMS in my camper. Now all of a sudden, the charger Relais clicks when I plug external power in, but the Relais flips back out and does not charge the battery. Temperature is above 7degree and the votronic booster charges fine, so the battery is not the issue. I did not change the settings either after it initially worked nor did I fuck up the wiring... also, the settings fit the German power grid and leave enough room for
can anybody please tell me your thoughts on my issue? What could be the reason for that and how donI fix it?
thank you so much in advance. Btw - this is my first post in any forum ever so please do make this a wonderful adventure ;-)
best regards,
simon
