Hello, how does the MultiPlus switch off in normal operation without emergency (intervention by BMS) when the battery is empty?
It can be sent to turn of at a particular SOC or voltage using its internal battery monitor. (Not accurate if you have DC loads other than a multi)
Or you can set up an assistant to use the relay on a BMV-7xx and aux input to signal the multi to shutdown at any number of criteria. but usually SOC is used.
23 People are following this question.
