Hi all,
Getting UL certifications is a very long process, and since it involves independent laboratories, Victron is often unable to offer any estimate of when a particular component will be approved - particularly in times like these when the entire planet is on staggered shifts at best, and complete shutdowns in many cases.
As always, please keep an eye on Victron's Certificates Page, as that's where you'll find the actual certificates themselves as soon as they're granted, and also of course the Weekly News blog that you can access through your Victron Professional account, as that's where things of this nature will be published first.
Cheers!
Or some guidance on what is attempting to be UL certified with the bigger Quattros? The silence has been deafening, both in the forum and in the weekly news blog.
is the Victron Multiplus-II 48V/5000VA inverter charger UL Certified ???
As of this date, no, in the MultiPlus-II 48v range so far only the 3kVA has a UL1741 cert. To stay up-to-date, better to keep an eye on the "Certificates" page for your desired product.
https://www.victronenergy.com/inverters-chargers/multiplus-ii#certificates
29 People are following this question.
