bezda avatar image
bezda asked
MultiPlus Compact not turning on and flashing orange
Hi, since I've installed victron lithium batteries with BMS and mains detector, I'm having trouble switching on my multiplus compact using the rocket switch. It just starts flashing orange (not a full diode flash, just a tiny blink) and does not turn on till I connect my generator for a little bit. Any suggestions how to fix that?
Jack Peters avatar image
Jack Peters answered ·
Did you add the VE.Bus BMS assistant to the MultiPlus?
mattsnow avatar image
mattsnow answered ·
Hi, I realise this is an old post but this is the only source anywhere on the internet I can find describing this problem.
What does this rapid flash of the orange charge LED mean and how can it be resolved??
I have now gone through two Multiplus 1200 that have thrown this issue.
