mix avatar image
mix asked
Replacement screw MPPT 75/15
I'm installing my MPPT 75/15 charge controller and I see that screw that holds the bat - tight is missing.
Where on earth could I find a replacement??
I'm thinking removing a load screw out, since I don't plan on using it, but that's not working well.
A replacement would be the best.
- Crawling around on the floor, searching and swearing.
MPPT Controllers
Paul B avatar image Paul B commented ·
Maybe it would be easier to take the one you have in the other connection and head off too the tool shed or the hardware store and replace the screw with a new one.
mix avatar image
mix answered ·
The replacement screw I found was a M3 .50 pitch x12mm.
Thank you for reporting back. Sorry it was missed the first time you posted.
